How we can identify the source of Good-issue in Hospitality Management Add-on?
Query
How can we identify the source of Good-issue in Hospitality Management Add-on?
Answer
iVend Hospitality saves the Transaction ID/Order ID against the Good-issue as shown below:
Hospitality Get Order Screen
Above Order ID (Transaction Code) is AVN277.
A Good-issue is created against the Order ID as shown below
In the above Good-issue screen, you can see that the reference number is AVN277 i.e. Order ID (Transaction Code) generated against the Order.
So we can understand with it that any Good-issue when created that gets reference number allocated as Order ID (Transaction Code)
Good-issue Details
So Good-issue details can be tracked the as per above information.
    • Which are those events when Good Issue Documents are created in iVend with Hospitality Add-on
      Query: Which are those events when Good Issue Documents are created in iVend with Hospitality Add-on automatically? Answer: There are 3 instances in which a Good issue document is created in Hospitality processes. Below are these 3 instances: 1. When ...
    • iVend Hospitality Feature List
      Note: This Feature List is based on iVend Hospitality version 1.1 Restaurant Master Data Management iVend Hospitality provides highly configurable system settings. It comes with default data, multiple masters, data mapping screens and views, which ...
    • Need to Identify Sales Person on Every Sale Transaction
      Product version: iVend 6.6 7989 Problem statement: Need to Identify Sales Person on Every Sale Transaction Symptoms: Customer Wants to identify his Sale by Sale Person on every Month end. Proposed Solution/Workaround: As a workaround we shared a ...
    • Debug the Registered Add-on
      Debug the Registered Add-on This knowledge base article will assist developers on how to debug the registered iVend Retail Add-on using Microsoft Visual Studio. Purpose: The key intent to debug and test the registered iVend Retail Add-on code is to ...
