How to import and export Customer Balance and Credit Limit
How to Export and import Customer Balance and Credit Limit amount
Please follow below steps
Step 1 :
Login HO MC and go to Administration -> Application Setup-->Export Data -> Select Order Type as Accounts Receivables
Step 2:
Click on Ok and Search the customers and Export the Account Receivable data in Excel file
Step 3:
Make changes as per your requirement in excel file in  as per below screenshot
Step 4 :
After save the changes Import the same excel file from import Data option
This will Update the Customer Balance and Credit limit.
Alert
Note : We recommend you to test this process first on Test Environment and then apply it on Production
    • Customer balance exceeds the credit limit
      Product version: 6.5 update 6 patch 2 : The customer has a credit limit of 67 479.66 and an Order Balance of 3 280.00. The balance of the credit limit is -67 479.66 and yet POS still giving an error that the customer balance exceeds credit limit. ...
    • Customer Credit limit with limited Credit days
      Environment: iVend Version 6.6 with SAP B1 9.2 Problem Statement: We are not able to issue the credit days, the credit limit for the customer, and not able to charge interest on credit days as well. We don't have any consolidated report of the credit ...
    • Export and Import Security Rights
      Export and Import Security Rights Security Role is added to the object type of Import data and Export Data. This means that Security rights can be exported from one system and can be imported into another system. Benefit Security roles can be easily ...
    • Import/Export User Defined Table
      Introduction iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows to extend business logic either in Management Console or at the Terminal POS. The addon framework allows deployment of ...
