How to debug Error related with store initialization
Environment : iVend 6.6  integrated With SAPB1
Problem Statement : During the store initialization an error message has been encountered while configuring the Replication service for the store and the store were not initialized. Below is the attached error.
Symptoms: NA
Resolution/Work Around:-Below are the step to find root cause of issue
1.Create a test database by create restore store database.
2.Copy backup from Enterprise database and rename extension from .backup to .sql.It will show warning message click on Yes
3.Open the zip file and copy the script.sql in sql and execute.
4.It will show the exact error which are coming on excute.Click on Error it will show table name in which error is coming.
5.In this case issue is due to some custom table  and trigger created .Issue resolved after delete custom table  and trigger created.
Recommendations /Suggestion: NA
Recommendations /Suggestion: This article is created only for Support team and such activities should be done along  with  product expert
    • While sending the test email it thrown error as "The SMTP server requires a secure connection"
      Environment: iVend Version 6.6 Problem Statement: While sending the test email it thrown error as “The SMTP server requires a secure connection or the client was not authenticated. The server response was: 5.7.0 authentication required”. Error ...
    • Debug the Registered Add-on
      Debug the Registered Add-on This knowledge base article will assist developers on how to debug the registered iVend Retail Add-on using Microsoft Visual Studio. Purpose: The key intent to debug and test the registered iVend Retail Add-on code is to ...
    • error message:- Initialization Failure "invalid column name"
      Problem: Management Console could not be launched after initializing the store While Initialization a new store , getting error message “Invalid column name 'CustomerDisplayKey' or Invalid column name 'IsCustomerDisplayEnabled’” while launching the ...
