How to configure hardware registration for printer
How to configure hardware registration for Printer
iVend Hardware
Environment : iVend Version 6.6 with SAPB1 10
Query: How to configure hardware registration for printer.
Symptoms : How to configure hardware registration for printer.
Resolution/Work Around : Kindly follow the below Steps.
Open the OPOS configuration utility for the printer and check the test print. test print result should be successful.
2. Follow the below path and open the hardware registration for printer configure the device name.
Administration --> Retail configuration --> Hardware registration
Enter the device name from OPOS hardware utility.
Please Note : We can follow the above steps for cash drawer hardware registration also. We need to test the cash drawer OPOS hardware utility and then configure the cash drawer device name.
Steps configure Document Printer in iVend Retail
Step 1: The Document Printer must be configured under Hardware Registration, ensuring that the correct Assembly Name and Class Name are specified. Step 2: The Hardware Registration should be linked as a Document Printer within the Hardware Profile. ...
Hardware Setup for the POS
Configuring Hardware Peripherals for iVend POS In this topic we will look at the steps required to setup, install and configure the Hardware Profile for the POS, including two main hardware components that are connected to the POS that operate using ...
Configuring Printer in new iVend Setup
Product version: 6.2 Onward Problem Statement: In the new installation of iVend, Configured OPOS drivers now are compatible with Windows as the OPOS drivers can communicate with the printer and print data sent to it, but iVend POS cannot use the ...
Hardware list is showing Empty on Point of sale
Thermal Receipt Printer in Ivend
IVend Version: 6.5 UPDATE 6 Problem Statement: Thermal Receipt Printer doesn’t work in IVend Trying to attach a thermal receipt printer with iVend, in case POS is not sending the print to OPOS driver but it's sending print for the same printer to ...
