Goods Return with GRPO only
iVend 6.5 update 6 with SAP IS Retail version ECC 6.0
A request comes to make Good Receipt PO field mandatory on Goods Return screen.
On Goods Return Screen right click on Good Receipt PO field and see that ‘Make this field mandatory’ is disabled. This field is non mandatory because of standard iVend behavior.
Requested functionality is not available in current version of iVend.
Version 6.5 update 6, patch version – 2021_23
Version 6.6, patch version - 7825
Proposed Solution/Workaround:
This request is not the part of standard iVend behavior so it is difficult to achieve in base product.
Suggestion:
Any request like this which is not the part of iVend standard behavior can be checked with custom development team for feasibility.
iVend POS - Goods Return
Introduction In this article we will review the Goods Return functionality at the store. This inventory transaction is part of suite of Business Transactions that can be found in the Management Console that take place at the store. This type of ...
Goods Return Creation -SAPB1-GRPO "(-1)The Good Return has some items which are marked for store"
Environment iVend 6.6 integrated with SAP B1 9.2 Symptoms Customer was not able to create Good return in sap. Problem statement At the time of Good return against GRPO "(-1)The Good Return has some items which are marked for store" in SAP. ...
Error on SAP "This GRPO has items from PO which were marked for store"
Product version: iVend 6.6 with SAP Business One Problem statement: Purchase Order is Marked for “For Store” in SAP. SAP is not allowed to create the GRPO will show error “This GRPO has items from PO which were marked for store”. Proposed ...
GRPO Location Error
Environment: iVend 6.6 Problem Statement: GRPO Location Error Proposed Solution: While creating a new GRPO in-store, an error message shows "Setup Default Location For Warehouse. We need to define the default location for the warehouse. Once we map ...
Check Goods Receipt & Goods Issue against Inventory counting iVend MC
Environment: iVend 6.6 integrated with SAPB1 Problem Statement: How to check Goods Receipt & Goods Issue against Inventory counting iVend MC Symptoms: NA Resolution/Work Around: Below SQL Queries can be used to check: Select ...
