GiftCertificate not validate for duplicate serial number in Import data option
While upload the GiftCertificate from Import option from Management Console it does not validate the duplicate serial number.
Proposed Solution/Workaround:
If there were two entries for the same serial number, then for first entry for the insertion will happen and as soon as the same entry again comes then it will be the update instruction for system, no two entries will be committed in Data of same Gift Certificate.
Problem statement While upload the GiftCertificate from Import option from Management Console it does not validate the duplicate serial number. Environment iVend 6.6 Proposed Solution/Workaround If there were two entries for the same serial number, ...
Import Serial Coupons
Import Serial Coupons Enhancement has been done on the Import data screen by adding CouponSerialNumber to object type. This will facilitate import of valid range of serial numbers created from another system to be issued by serial number from the ...
Import Serial Coupons Enhancement has been done on the Import data screen by adding “CouponSerialNumber” to object type. This will facilitate import of valid range of serial numbers created from another system to be issued by serial number from the ...
Duplicate gift certificate with same serial number present on store
Problem Statement When gift certificate search is done two different gift certificates were present on store with same serial number but different amount. When the cashier tries to use the gift certificate at the register it shows invalid card. ...
Not able to receive a Stock Transfer in SAPB1 ErrorMessage: Not enough data
