GiftCertificate not validate for duplicate serial number in Import data option
Problem statement
While upload the GiftCertificate from Import option from Management Console it does not validate the duplicate serial number.
 iVend 6.6
Proposed Solution/Workaround
If there were two entries for the same serial number, then for first entry for the insertion will happen and as soon as the same entry again comes then it will be the update instruction for system, no two entries will be committed in Data of same Gift Certificate.
Case : CS0010738
