Error - SAP Business One Connection Error - No SAP Licenses.
Getting an error while updating the “Integration Service Configuration” – “SAP Business One Connection Error – No SAP Licenses”.
Proposed Solution/Workaround:
Need to make sure that license is available under the license Administration under the SAP under the correct company.
Need to make sure that the “CXSiVend ” user is marked for “Professional.”
Please make sure that the user is a Super user.
Steps
Login to SAP Business One>>Go to Administration>>License>>Click on License Administration.
Make sure that company name is correct for which you are configuring the integration service.
Confirm, by checking the company name under Allocation: -
Note : You can confirm, by using below path that if you are looking at the correct company name with the correct Database or not.
Login to SAP Business One>>Go to Administration>>Choose Company>>”Select Company".
Make sure that license is allocated under allocation.
Go to Assignment and make sure that ”CXSiVend” user has a check mark for “Professional”.
Constraints / Scenarios:
    • Error - SAP Business One Connection Error - No SAP Licenses.
      Problem Statement Getting an error while updating the “Integration Service Configuration” – “SAP Business One Connection Error – No SAP Licenses” Proposed Solution/Workaround: Need to make sure that license is available under the license ...
    • SAP Business One Connection Error -Error during SBO user authentication
      Product Version iVend 6.6 integrated with SAP B1 Problem Statement At the time update Integration Service Configuration service customer was facing below error message “SAP Business one connection error : Error during SBO user authentication” ...
    • SAP Business One Connection Error - Password has expired
      Problem: Getting an error “SAP Business One Connection Error - Password has expired” while updating the Integration Service. Cause The above error occurs when the password of the SAP user CXSiVend got expired. Procedure: Open SAP B1. Login with the ...
