Default quantity at POS with condition
Is there a way to configure iVend to automatically set the default QTY per product on selecting the item at POS? For example, if an item name does not start with X-, then the default QTY for that item is 6.
If an item name starts with X-, then the default QTY for that item is 5.
As per current functionality one can set the default quantity of a product to be displayed at the POS when the product is selected for any transaction through the item master screen in Management Console.
Refer to the below screenshot.
However, there is no functionality available as such to set the default quantity for all the products for a particular condition as stated in the above example.
but as a workaround one can achieve this by using export or import functionality in iVend.
Steps if any:
Export all the products and then set the default quantity for all the products as required by applying filters in excel and then import it.
Constraints / Scenarios:
Restrict user to change the product quantity in POS screen.
Environment: iVend 6.6 Problem statement: Restrict user to change the product quantity in POS screen. Solution/Work Around: As a workaround,in the retail profile , you can check box "change qty" inside the manager override so whenever user changes ...
Not able to increase/decrease line item quantity at POS
Environment: iVend Version 6.6 7702 Problem Statement: Customer is not able to increase and decrease the line item quantity with the help of + and - buttons on the POS screen. Symptoms: It is a POS operational issue and it is working with the ...
Steps to modify the default Quantity of all the products in one go
Query: How to modify the default Quantity of all the products in one go. Resolution: The default quantity of the product is defined in the Item Master data setup. One can use the export and import functionality of iVend to carry out a mass update in ...
Weighed Product Quantity Prompt Not Appearing at POS — Behaviour Based on Stock Level
Issue: At the iVend POS (Store ABC ), a product configured as a Weighed item does not show the manual quantity input prompt during a sale. Instead, the system automatically defaults to a fixed quantity (e.g., 300) rather than prompting the cashier to ...
Layaway:Restriction on Increase Quantity
Environment: iVend 6.6 with SAPB1 9.2 Problem Statement: While using Transaction Mode as Layaway , iVend POS doesn't allow to increase the item's quantity . it is restriction on Increase Quantity. Symptoms: While using Transaction Mode as Layaway , ...
