Datec Fiscal Printer Error “Tax Rate Not Found” After VAT Rate Change
Product Version:
iVend Retail 6.6
After updating the VAT rate from 16.5% to 17.5%, fiscal receipt printing fails on Datec fiscal printers. Although transactions are completed and saved in iVend, the fiscal receipt does not print fully, and the printer enters an error state, displaying “Tax rate not found.
Symptoms :
  • Receipt prints partially and stops
  • The fiscal printer goes into error mode
  • Receipt is not fiscalized
  • POS transaction is saved successfully.
  • Issue observed across all stores and POS terminals
  • An error appears after the VAT rate change without a firmware upgrade
Root Cause :
The VAT code configured in iVend Hardware Setup was not updated to match the newly changed VAT rate. Datec fiscal printers strictly validate VAT rate mappings at the hardware configuration level, and a mismatch results in the “Tax rate not found” error.
Proposed Solution :
  1. Open iVend Hardware Setup.
  2. Navigate to the Datec Fiscal Printer configuration.
  1. Locate the VAT Code mapping.
  2. Update the VAT code to correctly reflect the new VAT rate (17.5%).
  1. Save the configuration.
  2. Restart the POS and re-test fiscal receipt printing.
After correcting the VAT code in the hardware configuration, fiscal receipts print successfully, and the printer operates normally.
Suggestion :
  • Not applicable
    • iVend Retail - Fiscal Printer Integration
      Fiscal Printer Integration Who should be reading this document? The target audience for this document is intended for partners who are willing to undertake source code modification under license from CitiXsys to pursue customisations. This document ...
    • Tax number field locked
      Environment: iVend 6.6 Patch: 7989 Problem Description: Tax number field locked Scenario: Unable to edit the Tax number field in customer Master, even though validation rule in not set for the particular field. Solution: 1) Go to Retail Profile >> ...
    • "Sales Tax with 0 rate can't be applied for Tax Free customer.
      Product Query : Unable to Apply Tax Free – Error "Sales Tax with 0 rate can't be applied for Tax Free customer." iVend version : 6.6 8024 Symptoms: Users are unable to apply Tax Free for a customer in POS. The following error message is displayed: ...
    • iVend to SAP Intgartion Error : Credit Card - CUSTOM not set neither for the warehouse nor on the Retail Tender in SBO
      Environment :  Ivend 6.6 Problem statement : iVend to SAP SAP B1 Integration Error : Credit Card - CUSTOM not set neither for the warehouse nor on the Retail Tender in SBO Symptoms: Sale Transactions is not integrating from ivend to SAP B1. Below ...
