Data not integrating from iVend to the Sage x3
Product Version:
iVend 6.6 and Sage X3
Proposed Solution/Workaround:
We Check the data and find the below reason.
  1. We found that there are some transactions that are batch enabled but batch is not available in iVend HO.
  1. Items is mapped from with the warehouse but after transaction they remove warehouse, so it is required to hard delete the warehouse from iVend
Steps if any :
None
Constraints/Scenarios :
N/A
    • Data not integrating from iVend to the Sage x3
      Product Version: iVend 6.6 and Sage X3 Problem Statement: Data not integrating from iVend to the Sage x3   Proposed Solution/Workaround: We Check the data and find the below reason. We found that there are some transactions that are batch enabled but ...
    • Goods receipt not integrating to Sage X3 when initiated from iVend
      Environment: iVend 6.6 Patch 7747 Problem Description: Goods Receipt transaction not integrating to Sage X3.Subsequent transactions like Goods return, Goods Issue etc are stuck in the integration monitor. Scenario: When creating the Good Receipts for ...
    • iVend Retail for Sage 300 Released
      Introduction This article pertains to the release of the Integration between iVend Retail and Sage 300, which has been developed using iVend Extensibility and the Sage 300 APIs. With this release Sage 300 retailers can now achieve their omnichannel ...
