Goods receipt not integrating to Sage X3 when initiated from iVend
iVend 6.6 Patch 7747
Problem Description:
Goods Receipt transaction not integrating to Sage X3.Subsequent transactions like Goods return, Goods Issue etc are stuck in the integration monitor.
Scenario:
When creating the Good Receipts for more than 200 items and its subsequent transactions like Goods return, Goods issue etc are stuck in the integration monitor.
Cause:
For Good Receipt having items 200 or more it is not integrated with Sage X3 simultaneously due to product master inactivation in SageX3.
1) Check that for Good receipt having 100 - 50 items is it integrated from iVend to Sage X3 or not.
2) Check the item master data in SageX3 and ensure that all new items created in Sagex3 should be activated and moved in iVend; which are used in current transactions, good receipts, good return as well as good issue.
3) Also verify that when items created in SageX3 it has been simultaneously updated in iVend or not if not then activate it.
We have informed client to check the items which are used in the transactions that whether these items are activated or not and asked from client to check the integration by creating a dummy Good Receipt in iVend system with more than 100 items additionally need to check that the items created in SageX3 will integrate into iVend simultaneously or not.
    • Data not integrating from iVend to the Sage x3
      Product Version: iVend 6.6 and Sage X3 Problem Statement: Data not integrating from iVend to the Sage x3   Proposed Solution/Workaround: We Check the data and find the below reason. We found that there are some transactions that are batch enabled but ...
    • Check Goods Receipt & Goods Issue against Inventory counting iVend MC
      Environment: iVend 6.6 integrated with SAPB1 Problem Statement: How to check Goods Receipt & Goods Issue against Inventory counting iVend MC Symptoms: NA Resolution/Work Around: Below SQL Queries can be used to check: Select ...
    • iVend POS - Goods Return
      Introduction In this article we will review the Goods Return functionality at the store. This inventory transaction is part of suite of Business Transactions that can be found in the Management Console that take place at the store. This type of ...
