Coupon Fails to Apply Discount When Product Quantity Exceeds One
The coupon does not give a discount on all quantities if the product quantity is more than 1.
Scenario :
The user configures the Coupon to give a 10% discount on the product, but it gives the discount only on 1 quantity if there are more than 1 quantity.
Example: At the time of redeeming the coupon, the discount value is showing 25 instead of 500,
Suggest increasing the Applicable quantity to 999.
A/R Invoice see different discount between iVend and SAP B1
Problem Reported : Customer notified to us about different A/R Invoices between iVend and SAP. they realize that they have a difference in the discount between SAP and iVend, it is showing discount negative and decimal less than one. Cause : ivend ...
SAP Business One - iVend Retail Integration Points
Apply more than one coupon on the same line of the sale transaction
Version 6.6 and not the version-specific Query We would like to know if there is any configuration so that a coupon can be applied more than once to a line in the same transaction. Response We have checked and verified below scenario on iVend Retail ...
Apply direct discount to certain products within a specific product group
Environment: iVend Retail 6.6 7825 Product Query: "How can I apply a 75% direct discount to certain products within a specific product group?" Symptoms: N/A Resolution/Work Around: check below steps along with configuration. 1: Make a new category ...
