Apply direct discount to certain products within a specific product group
Environment:  iVend Retail 6.6 7825
Product Query: "How can I apply a 75% direct discount to certain products within a specific product group?"
Symptoms: N/A
Resolution/Work Around: check below steps along with configuration.
1: Make a new category for products. Connect the right products to this category.
2: Go to the Bonus Buys Screen.
Press the New button and write down the code and description.
3: Click on 'Applicable', then add a store, attach the right store, and press OK.
4: Tap on the Setup button, then choose 'Buy Products', and pick 'ALL' for Product Type.
Get Products Select "Product Type", attach them to the right "Product Category", then press OK.
5: Check the Check box “Discount allowed” on Product Master for one Product.
6: Login Point of Sale and Scan Product.
Test the scenario first in Test environment.
