Can we make a Warehouse as Retail after it is created.
Query
While creating a New warehouse in SAP the Retail Warehouse Checkbox was not checked, is it possible to check it after the warehouse was created?
Solution
Once the warehouse is created then it cannot be edited as Retail in SAP.
For freshly created WH (which somehow got wrongly configured) you can mark it as Inactive (Refer Below image) and create a new retail Warehouse.
Retail Profile
Retail Profile The Retail Profile allows for the setting up of the system specifically for POS related information, which can then be applied to the POS at the store. It is important to note that a Retail Profile can be specified at the User, POS, ...
Warehouse creation in SAP R3 and its effect in ivend
Product version: iVend 6.5 update 6 Problem Statement: Stock transfer request only created between warhouses which mapped to stores(Retail) and not General Warhouse. Proposed Solution: NA Steps if any: In SAP R3 , value needs to be passed from ...
iVend Retail - Overview and Architecture
Overview and Architecture This article gives an overview of iVend Cloud. The article also discusses the different applications and modules of iVend Retail, brief description of these modules and finally overview of how the application suite is ...
iVend Retail - Stock Transfer Enhancements in iVend with SAP Business One
iVend Retail - Stock Transfer Enhancements in iVend with SAP Business One In iVend Retail enhancements have been done to use standard SAP Business One Inventory transfer documents for Stock Transfers between the General Warehouse using SAP Business ...
