Can we define the 50000 in the Max quantity per transaction in Product from iVend
Query:
Customers want to define the 50000 in the ' Max quantity per transaction ' from iVend.
We found that the system doesn't allow above 9999 in the ' Max quantity per transaction ' . How can we set it? Please assist us.
We would like to inform you the maximum quantity per transaction is 9999  as per the design. So we can not set more that 9999 in Max Quantity Per transaction column in Product creation at iVend.
    • Default quantity at POS with condition
      Environment: iVend 6.6 Problem Statement: Is there a way to configure iVend to automatically set the default QTY per product on selecting the item at POS? For example, if an item name does not start with X-, then the default QTY for that item is 6. ...
    • special price of product would be changes as per Discount if Auto Update is False.
      Product Version: iVend 6.6 (Actual functionality of Ivend for all version) Problem Statement: (INC0010921) special price of product would be changed as per Discount if AutoUpdt field is updated as False. Proposed Solution and steps taken: While ...
    • iVend Retail- Transaction Roll-up
      iVend Retail – Transaction Rollup The Transaction Rollup feature is used to reduce the volume of transactions integrated into an ERP. It is recommended to use this feature when transaction volumes are large. Note: In this article we will use SAP ...
    • iVend POS Transaction Server
      iVend POS – Transaction Server Transaction Server is an API service hosted on the iVend Enterprise. Transaction Server reduces the data replication across the store network when Inter-store Transactions has been enabled in the system or when SQL ...
