iVend Add-on Framework is used for writing Custom Business Logic independently by a programmer. iVend Addon allows extending business logic either in Management Console or at the Terminal POS. The addon framework allows deployment of multiple Add-Ons on one Enterprise. The extended business logic is deployed as an Add-on centrally at the Enterprise which then gets auto-replicated to the entire retail landscape.
