Understanding Inventory Showing in the INTRANSIT Warehouse in iVend Retail
Overview
The INTRANSIT Warehouse in iVend Retail is a system-managed warehouse used during stock transfers between locations.
When a stock transfer is initiated:
Inventory is deducted from the source warehouse
Inventory temporarily moves to the INTRANSIT warehouse
Inventory is updated in the destination warehouse once the transfer is received
Why Inventory Remains in INTRANSIT
Inventory may remain in the INTRANSIT warehouse if the stock transfer receipt process is not completed.
Common reasons:
Pending stock transfers
Delayed receipt at destination store
Interrupted or cancelled transfer process
Pending inventory operations
Common Symptoms
Inventory visible in INTRANSIT warehouse
Negative quantity at source warehouse
Missing stock at destination warehouse
Inventory mismatch between stores and HO
Example Scenario
Normal Transfer Process
Source Warehouse
INTRANSIT Warehouse
Destination Warehouse
Incomplete Transfer Process
Source Warehouse
INTRANSIT Warehouse
Destination Warehouse not received
Recommended Resolution
Review pending stock transfers in the system
Verify whether the stock was physically received at the destination
Complete pending stock transfer receipts
Recheck inventory balances after receipt completion
Note/Suggestion:
If the issue persists, contact the iVend Support Team for further investigation.
SAP B1 Retail Warehouse showing as InTransit in iVend Retail
Problem statement : SAP Business One has a retail warehouse configured, but when creating a store in iVend, the same warehouse is appearing as an In-Transit Warehouse. iVend version : 6.6 7989 Symptoms: This problem generally occurs when users ...
How to revert inventory from intransit to General warehouse
Environment: iVend 6.6 integrated with SAPB1 Problem Statement: User wrongly created Stock transfer from General warehouse to Retail warehouse marked "For store" for store which does not exist in iVend and inventory is stuck in the Intransit ...
Warehouse cannot be retail store or retail intransit warehouse, Error in SAP while creating a GR
Version: 6.6, not the version-specific Issue: Error in SAP while creating a Good Receipt (GR), below is the error: "Warehouse cannot be retail store or retail intransit warehouse". Solution: This is the validation which does not allow to create GR in ...
Require to make the inventory as Zero for particular store
