Till Count Cash Denomination Order issue.
Short Description:
Product Query:  The denominations of the coins and bills must be in the order of value.
It is expected that the denominations should appear in order of their value and should be displayed like below
Recommendations /Suggestions:
This is working as per the current application design.
Denomination details are displayed in the same order in which they were created.
Note : CS0008426
    • Till count Standard report (Drawer Count) is showing wrong results.
      Product Version : iVend 6.6 Problem Statement : Till count Standard report (Drawer Count) is showing wrong results. Proposed Solution : We have used sql profiler and found in the report query where clause(rownumber=1) is mentioned wrong that why ...
    • Till Mgmt and End of Day Processes in iVend Retail
      Master Till The first step is to create the Master Tills. Each till requires a unique master record to be defined and then from this the user can set up the reusable tills. Each master till is used to generate the tills for use at the POS each ...
    • How to include all payment type while doing till count
      Problem Statement User reported that they encounter missing Integrated Credit Card information when performing Cash out - Till Count. Please assist to include all payment type of till count. Version Not the version-specific Resolution There is one ...
    • Till is not showing in POS
      Till is not showing in POS This article will demonstrate to resolve the till issue, where till is not showing in POS, however, till has been created into the management console and it is displaying in Master till and till has been assigned. Case ...
    • Till Variance
      Environment: iVend 6.6 with SAP B1 9.2 Problem Statement: Reviewing the Till Variance Log in SAP Business One and there is a column for Closed with values Y and N. For the variances with N status, is there a need to mark them as closed ? Symptoms: ...
