Till is not showing in POS
This article will demonstrate to resolve the till issue, where till is not showing in POS, however, till has been created into the management console and it is displaying in Master till and till has been assigned.
Case Study:
The below example is a case study where the till has been created in the Management console and it is showing in till with status New. As per the below Screenshot.
I. Created Master till as per the below Screenshot by using below navigations.
Operations >>  Till Management >> Master till
Note: -Please check the below configuration points during creating a new till.
1.) Mode:-In this case Mode has select as “Team”.
2.) Team:-In this case team has selected as “store1team”
3.) Store:-In this case store has selected as” Store1-Store1”
II. After that till has assigned as per the below Screenshot.
III The till status is showing as “New” as per the below Screen.
Note: -The new status shows that this till(Till1) is ready to use after logging the POS by the user id and assign the cash drawer.
IV. Now the user has logged the POS and get the below result, where the list of till was not displaying to assign.
Cause:
This issue here was due to configuration of Employee setting, Where POS user has not mapped to the team, however, the till has configured into master till with setting mode as a team.
For the reference please find the below Screen.
Resolutions: -
The POS Screen is showing correct because as per the above configuration of Employee/User has not mapped into a team, however, we have created above master till with mode as a team.
Note1:-If you have created Master till with mode as a team, then the POS user should be mapped into that team which has mapped into Master till.
Note2: -You can create a Master till with mode as “User” as well for assign the Specific POS user as per the below Screen.
Workaround:
In this case study it was found that configuration of employee/POS user was wrongly configured, where POS User has not mapped into team. So to resolve this case we need to apply below steps.
Step1.Mapped the POS user into the team where till was not showing in the list as per the below Screenshot and navigations and select the POS user
Administration >> Human Recourse  >> Employee
Step2. Then Assignee this till through Management console by using below navigations.
Operations Till ManagementMaster till
Step3. By using the below Screen shot and navigation, check the status of that till. It should be as “Assigned”
Operations >> Till Management >>  till
Step4.Log in the POS by using POS user which is mapped above in team.
Step5.Please follow the below points
1.) Select listed Till
2.) Click on the “Assign” button of the above screen then select till will move left side.
3.) then select the left side till and click on use Drawer button and click OK button.
Step6. After complete the step5 points, the till will assign the POS user and POS will Open as per the below Screen.
Summary: -
As per the configuration of master till and Employee/User product behavior was correct. And there was a configuration issue.
    • The Till is not showing in POS after logging in to the POS system
      Version 6.6, not the version-specific Issue Till is not Showing in POS, customer created a new store location, and configuration/installation is completed. But facing issues with the Till. The Till is not showing in POS after logging in to the POS ...
    • Till Mgmt and End of Day Processes in iVend Retail
      Master Till The first step is to create the Master Tills. Each till requires a unique master record to be defined and then from this the user can set up the reusable tills. Each master till is used to generate the tills for use at the POS each ...
    • Fiscal Receipt not Printing at Till for Item with Serial Number
      Product Version : iVend 6.6 Problem Statement : Fiscal Receipt not Printing at Till for Item with Serial Number Proposed Solution : User has informed the issue that fiscal receipt printing is not happening for item with serial number. This was the ...
    • Performance issues on POS , After scanning of products data showing very slow on POS Screen.
      Product Version 6.5 Update 5 Problem Statement Customers are facing performance issues on POS while scanning products. Proposed Solution/Workaround We have checked our code and to confirm we have found promotions are getting executed in the ...
    • Drawer Count Window Not Appearing in POS
      Environment: iVend Retail 6.6 7989 & SAP Business One 9.3 Problem statement: Drawer Count window not showing after login in POS. Symptoms: “Count Required on Assign” Resolution/Work Around: Follow below steps to solve the issue. 1: Login in ...
