"System.Data.SqlClient.SqlException (0x80131904) String or binary data would be truncated.
Problem statement :
After creating the bank (CHINA CONSTRUCTION BANK) in SAP Business One, the event was stuck in the Integration Failure Log with the following error.
Bank Configuration in SAP B1
Error:
iVend version :
6.6 8929
N/A
Resolution / work around :
  1. Log in to SAP Business One.
  2. Identify the bank record that failed during integration.
  3. Verify the Bank Code length and ensure it is 20 characters or fewer.
  4. Remove the existing bank record from SAP Business One.
  5. Request support to clear the corresponding error entry from the Integration Log.
  6. Re-create the bank record in SAP Business One using a valid Bank Code (≤ 20 characters).
  7. Trigger the integration process again.
  8. Confirm that the bank record is successfully integrated with iVend Retail.
