Getting an error message "System.Data.SqlClient.SqlException (0x80131904): Execution Timeout Expired.
Such exceptions could be momentarily and might have caused because of extended wait time for record processing
Follow the below steps to reprocess the record.
1) Stop the integration Service
2) Clear the Temp folder where iVend Integration Service is configured
3) Restart the affected machine once.
4) Restart the SQL Server once.
5) Update the integration Service
6) Start the integration Service
7) Retry the failed records from iVend Integration Failure log screen and check.
