iVend addon restriction on SAPB1 user CXSiVend.
Environment  :
iVend 6.6 with SAP B1
Problem statement :
CXSivend user doesn't have the addon running
Symptoms :
why the 'MANAGER' USER has the addon active while the CXSIvend user does not.
 It is not allowed to login with  SAPB1 user "CXSiVend" because :-
1) SAPB1 "CXSiVend" is integration user through which iVend Integration process the data
2) if customer login with CXSiVend into SAPb1 and post the entries in SAPb1 , it will be considered that Integration processed the events.
3) There is internal inventory sync between SAPB1 and iVend and sometimes , it uses CXSiVend user to integrate inventory sync.
So it is not recommended that customer should use CXSiVend to login into SAPb1.
Note : it is restricted in iVend Addon code , not to use CXSiVend user
    • Unable to Start iVend Add-on in SAP Business One
      Environment: iVend Retail 6.6 7989 & SAP Business One 10.0 Problem statement: Unable to start iVend Add-on in SAP Business One Error:Access to the path 'C:\Program Files\SAP\SAP Business One\AddOns\CXS\CitiXsys iVend AddOn\CitiXsys Ivend AddOn.exe' ...
    • ISSUE WITH IVEND ADDON - HANA CLOUD
      Environment : iVend 6.6 Patch 7915 Problem Description : ISSUE WITH iVend ADDON - HANA CLOUD Scenario : In the process of migrating iVend version 6.6 patch 7915 after installing the iVend add-on that comes in the patch 7915 folder but it is giving an ...
    • SAPB1 iVend Addon failed :AddOnInstallAPI.dll
      Environment : iVend 6.6 With SAPB1 9.2 Issue : While installing iVend Addon 6.6 , it displays the error message in SAPB1 Screen : error message: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog ...
    • Layaway:Restriction on Increase Quantity
      Environment: iVend 6.6 with SAPB1 9.2 Problem Statement: While using Transaction Mode as Layaway , iVend POS doesn't allow to increase the item's quantity . it is restriction on Increase Quantity. Symptoms: While using Transaction Mode as Layaway , ...
