POS Inventory view is taking long time
Inventory view on POS is taking long time to Open
Proposed solution/Workaround:
Whenever Slowness and performance related issue is reported please perform the steps below:
Run Below SQL Query to check Database Version
SELECT @@VERSION
In result check if SQL Server Version is Express Edition follow below steps.
Right Click on Database and Open Database properties
Check Database Size.
In SQL Server Express Edition database size limit is 10 GB (1250 MB).
The database will perform slow if the database size is near 10 GB and will stop accepting data if the database size reaches to 10 GB.
In the above case Data Purging needs to schedule for store and store should be reinitialized.
Require to make the inventory as Zero for particular store
Inventory View : Parameter :InventoryItemReplication
Environment: iVend 6.6 8567 SAP B1 Problem statement: Unable to view inventory of all warehouse. Symptoms : Only intransit and its own store inventory showing Resolution/Work Around: We found customer not able to view inventory of all warehouse . ...
iVend POS Slowness Issue taking time to close one Check
Product Version iVend 6.5.6 Patch 2 Problem Statement IVend POS Slowness Issue (Currently System taking 2-3 minutes to close one Check ). Proposed Solution Sometimes users are facing problems with iVend POS slowness issues and because of which the ...
View Inventory on POS : Failed on POS machine connected to on-premises Store.
Problem Statement There is one scenario : Getting an error "Inventory Status updated from enterprise server failed" while clicking on Retrieve from Server button at POS machine however another POS machine ( connected to same stores) doesn't have this ...
When we try to open the MC it takes a long time to load
Version: 6.5, not the version-specific Issue: When we try to open the MC it takes a long time to load. The Issue is below: 1) when trying to open the MC – it takes a long time to load. 2) when trying to export a new store DB, it takes at least 30 ...
