iVend Add Connect with SAPB1 HANA-on Error invalid sequence: SEQ_REPINTEGRATION
iVend 6.6 integrated With SAPB1
At the time of connect add-on in SAP Business One system gives the error and on Addon log file below Error Message Appear [SAP AG][LIBODBCHDB DLL][HDBODBC] General error;313 invalid sequence: SEQ_REPINTEGRATIONLOG: line 36 col
Below query require to be run on CXSINTEGRATION database to correct sequence
create sequence "CXSINTEGRATION".SEQ_REPINTEGRATIONLOG START with 1 increment by 1
This article is created only for the Support team and will be done along with product experts.
install add-on ivend for SAP B1 HANA and sync data between ivend and SAP B1
Environment: iVend 6.6 With SAP 10 HANA Problem Statement: User created fresh environment with IVend 6.6 Integrated with SAP version 10 With HANA 2.0.After installing ADD_ON encountered error message and failed to connect. Proposed solution: There ...
iVend Retail Add-on Execution Sequence
Introduction This knowledge base article explains the iVend Retail Add-on execution sequence in the iVend Management Console. Environment: iVend Version 6.5 Overview The iVend Retail Add-on contains business driven code and deployment is performed in ...
iVend Retail Add-on Execution Sequence This knowledge base article explains the iVend Retail Add-on execution sequence in the iVend Management Console. Overview The iVend Retail Add-on contains business driven code and deployment is performed in the ...
Integration Error "System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB"
Environment: iVend 6.6 integrated with SAPB1 HANA Problem Statement: Integration was not working and its showing below message on Event Viewer Log “System.Data.Odbc.OdbcException (0x80131937): ERROR [HY000] [SAP AG][LIBODBCHDB DLL][HDBODBC] General ...
ISSUE WITH IVEND ADDON - HANA CLOUD
Environment : iVend 6.6 Patch 7915 Problem Description : ISSUE WITH iVend ADDON - HANA CLOUD Scenario : In the process of migrating iVend version 6.6 patch 7915 after installing the iVend add-on that comes in the patch 7915 folder but it is giving an ...
