Inventory Data not replicated with setting Replicate Inter-Store Inventory.
Product Query:
Can we check Business transaction like Goods Issue, Goods Receipt etc of one store in another store using functionality "Replicate Inter Store Inventory" (Shown in the below image):
When  Goods Issue, Goods Receipt, Goods Return, and Stock Transfer document(s)  are created, inventory logs generated will not be replicated to the other stores.
In iVend 6.6, even if the setting "Replicate Inter Store - Inventory" is enabled inventory log will not be traveled inter store.
Inventory Management Options in Enterprise
Inventory Management Options in the Enterprise The option to enable or disable replication between the stores is available under the Enterprise settings in iVend Management Console. Log in to the iVend Management Console, navigate to: Administration ...
Inventory movement / management modifications in iVend version 6.6
Environment: iVend version 6.6 Product Query: In this Knowledge article, we will understand few modifications done in Inventory management in iVend version 6.6. Solution: Inventory movement/management modifications in iVend version 6.6 In iVend ...
Require to make the inventory as Zero for particular store
Inventory Count Document not Replicate from Store to HO
Product Query : Inventory Count Document not Replicate from Store to HO. How to check Inventory Difference on HO ? Answer : Inventory Counting document made on Store is not getting replicated to HO. However, corresponding GR & GI replicate to HO with ...
iVend MC Enterprise Setting "Inter Store Transaction"
--INTERNAL TO CXS SUPPORT TEAM--- Problem Statement In the Enterprise Setting section, User selected the 'Use Inter-store Transactions' field. want to uncheck it but the system does not allow it. Environment iVend 6.6 With SAPB1 Symptoms NA ...
