Inventory Count Document not Replicate from Store to HO
Product Query :
Inventory Count Document not Replicate from Store to HO. How to check Inventory Difference on HO ?
Answer :
Inventory Counting document made on Store is not getting replicated to HO. However, corresponding GR & GI replicate to HO with Inventory details. User can run the Inventory audit reports to retrieve inventory details on HO.
Require to make the inventory as Zero for particular store
Inventory Data not replicated with setting Replicate Inter-Store Inventory.
Environment: iVend 6.6 Product Query: Can we check Business transaction like Goods Issue, Goods Receipt etc of one store in another store using functionality "Replicate Inter Store Inventory" (Shown in the below image): Proposed Solution: When Goods ...
Inventory counting information not replicating to HO.
Query: - Inventory counting performed at store doesn't replicated to HO server. Store database showing data in the table InvInventoryCount but the same table on HO database is empty. Answer: - We would like to inform you that the inventory counting ...
Check list for move the inventory from one store to other store before closed the store
Product version: iVend Version 6.6 with SAPB1 10 Problem statement: Check list for move the inventory from one store to other store before closed the store. Symptoms: Check list for move the inventory from one store to other store before closed the ...
Replicate the item master only specific items
Environment : iVend 6.6 with SAPB1 Query : User created a new store in iVend, in the new store He wants to sell limited item in the stores, so he needs to replicate the item master only limited items and other materials are not required to replicate ...
