Inventory Management Options in Enterprise
Inventory Management Options in the Enterprise
The option to enable or disable replication between the stores is available under the Enterprise settings in iVend Management Console.
Log in to the iVend Management Console, navigate to: Administration > System Initialization > Enterprise – the Enterprise Settings Screen comes up.
Figure 1 – Enterprise Settings Inter Store Transactions Section
The recommended setting is to keep the option off for “Replicate Inter-Store Inventory”. This is to avoid unnecessary packet transfer over the network and to optimize the network for faster communication.
Figure 2 – Enterprise Settings Transaction Server Section
Switching On the transaction server will still show the real time inventory status of other stores by fetching information from the head office. The stores will still be able to get the inventory status and will be able to see real time inventory status of other stores without replicating data.
Figure 3 – Replicate Inter-Store Inventory Pop Up Message
On enabling the option for “Replicate Inter-Store Inventory”, a pop up message appears on clicking the enable checkbook. Click on Yes button to enable the Inter Store Inventory Replication. This will replicate the data between the stores. In this case the store will not fetch the data from Head office, rather will fetch the inventory data directly from the replicated store.
This concludes the KB on Inventory Management Options in the Enterprise.
    • Inventory movement / management modifications in iVend version 6.6
      Environment: iVend version 6.6 Product Query: In this Knowledge article, we will understand few modifications done in Inventory management in iVend version 6.6. Solution: Inventory movement/management modifications in iVend version 6.6 In iVend ...
    • inventory status updated from enterprise server is failed
      Environment: iVend 6.6 Problem Statement: We are getting an error message while click on tab "retrieve from server" under product setting Proposed Solution: Please follow the steps below: i) Enable transaction server settings on enterprise ii) Please ...
    • View Inventory error on store "inventory status updated from enterprise server is failed"
      Environment: iVend 6.6 with SAP B1 9.2 Problem statement: Inventory status update error Symptoms: Below error is faced while viewing the inventory of a product from the store. Resolution/Work Around: 1. Enable transaction server settings on the ...
    • iVend Loyalty Customer Registration Options
      iVend Loyalty – Customer Registration Options Overview How to add Loyalty Customers in iVend Retail iVend Loyalty provides various options for registration of a Loyalty customer. The process of registering a Loyalty customer depends on the ...
