6.6 integrated with SAP
Good Receipt stucked on Integration Failure Monitor with Error Message from iVend to SAP
System.Exception: DI:Target item number does not match base item number. [PDN1.ItemCode][line: 2] atReplicationSBOIntegrationWinSer.IntegrationObjects.GoodsReceiptPO.CreateGoodsReceiptPO(DataRow[] objDataRow, DataSet objDataSetSerialBatch, DataSet ObjDataSetSurcharges, DataRow[] objDataRowUserDefinedFields) at ReplicationSBOIntegrationWinSer.IntegrationObjects.Transactions.
Replicate(Direction From, Direction To, Int32 DatasetRowID) at ReplicationSBOIntegrationWinSer.Integrator.MainStart(DateTime LastRetryAt, Boolean Retried)
This error generally occur when purchase order item update from SAP after received Good receipt in iVend from original Purchase order.
Due to mismatch of item and line sequence it will show given Error
Suggested to check below Points
1.Compare Purchase order item code and its line number sequence into iVend Enterprise and SAPB1.
2.Compare GRPO item code and its line number sequence with purchase order of SAPB1.
