Integration Error System.Data.SyntaxErrorException: Syntax error: Missing operand after 'd130'
Product Version
6.6 integrated with SAP
Transaction stucked on Integration Failure Monitor with error message from iVend to SAP
“System.Data.SyntaxErrorException: Syntax error: Missing operand after 'd130' operator”
Proposed Solution
Issue is only reported on dated version iVend ver. 6.6 and Fixed on the latest branch of iVend release available for the production use.
Steps
Constraints / Scenarios
