HTTP Error 404.17 - Not Found The requested content appears to be script and will not be served by the static file handler.
Problem statement :
While browsing iVend API service from IIS it was giving the below error.
iVend version :
6.6 8864
Resolution / work around :
Issue resolved after installing the below WCF services.
- HTTP Activation
- Messsage Queuing (MSMQ) Activation
- Named Pipe Activation
- TCP Activation
- TCP Port Sharing
    • Unable to communicate with iVend Server
      Problem statement : While trying to set up the iVend handheld device, getting the below error: “Unable to communicate with iVend Server” Resolution / work around : For troubleshooting the issue, we need to follow the below two steps: Step 1: Check ...
    • License File not found
      Problem Statement:- License File not found. Problem Description:- An issue comes to a specific user while using the Item matrix on the terminal server. Troubleshooting attempts : -- Gave user full permission to the item matrix folder on the SQL ...
    • HTTP Error 500.21 -Internal Server Error Handler "PageHandlerFactoryIntegrated-4.0" has a bad module
      Environment: iVend 6.6 with SAP B1 9.3 Problem Statement: After doing a new Installation, when Replication service is started it is showing an error HTTP Error 500.21 - Internal Server Error Handler "PageHandlerFactory-Integrated-4.0" has a bad ...
    • Replication stuck and Not Moving
      Problem: Replication not moving from HO to Specific Store. Symptoms: Replication Log File Not generated and Event Viewer is showing "INVALID CLASS ERROR" What need to be Check : 1. Right Click on My PC 2. Click on Manage 3. Now Go to Services and ...
