UOM Id in Mobile POS transaction HTML receipt
iVend 6.6 8929
Is this possible to map UOM Id in Mobile POS transaction HTML receipt
We would like to inform you that iVend xml and Mobile POS xml are not same. currently Mobile POS XML receipt are working as per system design. for now UOM tag is not available in this HTML receipt. and if you want to add, then this the part of customization.
Multiple Receipt Printing issue
InventoryManagement UOM
iVend POS – Managing Inventory in Multiple Units of Measurement (UoM) With the introduction of the option to define multiple Units of Measurement (UoM) for a single product, the user now has the flexibility to maintain inventory in their choice of ...
Scan Sequence Resolution
Suspended Transaction XML Receipt Format
Suspended Transaction XML Receipt Format Environment- iVend 6.6 Problem statement – There is no by default base XML Receipt Format for Suspended Transaction. Resolution/Work Around: As per ivend current System design there is no such by default ...
Transaction code/transaction id not appearing on transactions receipt
Product version : 6.6 Problem Statement : Transaction code/transaction id not appearing on transactions receipt. ROOT CAUSE : 1. If the active chaeck box will unchecked , transaction id will not appear in transaction receipt. 2. End date in document ...
