Data not populating in UDF on Stock Transfer Receipt document
iVend Retail 6.6 7989 SAP Business One 9.3
Barcode not not showing while creating the stock transfer receipt.
It was checked that the Marketing Document UDF “Stock Transfer Receipt” was not integrate.
Issue resolved after integration U_Barcode UDF
Login in SAP Business One.
Go To: Administration >> System Initialization >> iVend Retail >> Marketing Document UDF Integration.
Check if the created UDF is integrated with iVend or not , if not then select UDF and check the check, Then click OK button.
N/A
Not able to receive a Stock Transfer in SAPB1 ErrorMessage: Not enough data
UDF creation on Stock Transfer Receipt in SAP Business One
Environment iVend 6.6 with SAP B1 9.3 Problem Statement UDF on Stock Transfer Receipt in SAP Business One Symptoms When a UDF is created in Stock Transfer Receipt related to the barcode in SAP B1 it doesn’t appear in Stock Transfer Receipt in SAP UI. ...
UDF (No Barcode field) on Stock transfer receipt screen.
Environment iVend Version 6.6 With SAP B1 9.2 Problem Statement There is no Barcode field on Stock transfer receipt screen (Screen to receive stocks from retail warehouse) in SAP B1 as shown below so we tried to create a UDF in table of stock ...
In Stock Transfer Request the "Request Number" field is not populating automatically.
Environment: iVend 6.6 Problem Statement: While creating a Stock Transfer Request the "Request Number" field is not populating automatically as shown below and the document number series is already defined. Cause: This issue generally occurs when ...
Duplicate Stock Transfer Shipment
Environment: iVend 6.5 Update 6 Problem Statement: While making a Stock Transfer receipt on receiving store MC, the user noticed that Stock Transfer Shipment is duplicated. Proposed Solution: CheckPoints: Check If stock Transfer Shipment Series is ...
