Currency disabled in Integrated Environment with SAP B1
Problem statement :
iVend version :
Not version specific
Resolution / work around :
In SAP Business One, you can check and remove currencies from the below menu path:
Administration → Setup → Financials → Currencies
From this window, you can review the currencies configured in SAP B1 and remove the unused currencies after verification.
Through integration, the same currencies will also be deleted from iVend.
Note :
    • Price lists integrated with another currency
      Product version : iVend 6.6 Problem Statement: Price lists integrated to iVend with another currency. Base currency is set as local currency in SAP ( e.g. XCD ) , however it is appearing as $ at POS and getting integrated as $ Proposed ...
    • Create test Environment from Live Environment for an integrated iVend Landscape
      Creating a test Environment from Live Environment for an integrated iVend Landscape As a good business practice it is always recommended to have test system in place in your landscape . Having a test box allows you to run or test any of the business ...
