Could not load file or assembly 'System.Data.SQLite.DLL' or one of its dependencies
Error :
System.IO.FileNotFoundException: Could not load file or assembly 'System.Data.SQLite.DLL' or one of its dependencies. The specified module could not be found.
Resolution:
As suggested by Development team we can remove the 'System.Data.SQLite.DLL' from the API Bin Folder and continue work as you are not using MPOS.
'System.Data.SQLite.DLL' is required only for MPOS.
