Can we temporarily disable Loyalty Accrual and Redemption
iVend 6.6.8929
Product Query:
Would it be possible to stop loyalty from being accrued and redeemed for a few days?
Resolution/workaround:
Customer can disable Loyalty accrual and redemption by following the below steps:
1. Open MC >> Operation >> Loyalty >> Loyalty Plan and disable the active loyalty plan.
2. Open MC >> Financial >> Payment Type and disable the Loyalty payment type option.
    • Multiple SMS for single Loyalty Transactions
      Environment : iVend Version 6.6 with SAPB1 9.2 Problem Statement: Multiple SMS for single Loyalty Transactions Symptoms : Multiple SMS for single Loyalty Transactions Resolution/Work Around : Due to SMS gateway ,not returning the success message, the ...
    • “iVend Loyalty Redemption: Configure Minimum Point Threshold for Redemption”
      Product Query : Customers requested a configuration where loyalty points should not be redeemable until a specific point value (for example, 200 points) is achieved. iVend version : 6.6 8929 Symptoms: N/A Resolution / work around : To address the ...
    • Disable "Register Loyalty Customer search" from user menu
      Environment: iVend 6.6 SAP IS Retail Problem Statement: How to disable "Register Loyalty Customer search" from user menu in POS Application. Proposed Solution: Below steps are followed, to impose restrictions on a user when they attempt to access the ...
    • Is it possible to control the redemption of loyalty points to be on particular products.
      Query: Is it possible to control the redemption of loyalty points to be on particular products i.e. Product A can be sold using Loyalty Tender type but product B cannot be sold using Loyalty tender. Resolution: To achieve this, we need to uncheck the ...
    • Loyalty Levels
      Loyalty - Loyalty Levels iVend Retail includes a fully featured Customer Loyalty program. iVend Loyalty is a points and rewards application designed to enhance the opportunities to win and retain new customers and greatly improve the overall ...
