iVend Handheld Compatibility Specification
iVend Handheld Compatibility Device specification.
Scenario:
iVend Handheld device specification and OS compatibility.
iVend Handheld for Android recommended (compatible) device make/model
Version of Android OS compatible with iVend 6.6
iVend Handheld for Android recommended (compatible) device make/model.
Any generic handheld device for Android available in the market. As per application design aspect we have not designed handheld for Print / Scan which can be integrated to iVend. So for the generic purpose and using any Android device is recommended.
Version of Android OS compatible with iVend 6.6.
Android 5.0 or above is compatible with iVend 6.6.
N/A
Environment: iVend 6.6 Patch 8024 Problem Description: iVend Handheld Compatibility Device specification. Scenario: iVend Handheld device specification and OS compatibility. iVend Handheld for Android recommended (compatible) device make/model ...
compatibility version SAP & SQL Version
Product Query Customer currently using the SQL version 2016 in HO and stores in 2008 express . SQL 2019 and higher version will support ivend 6.6? SAP Version 10 and Pl 2405 and higher PL version will compatible with ivend integration ? Answer As per ...
Is iVend 6.6 compatibility with SQL Server 2019?
Version: 6.6 Query: Is iVend 6.6 compatibility with SQL Server 2019? Answer: Yes, the below latest version of SQL is compatible with iVend 6.6 Miicrosoft® SQL Server 2019 - 64 Bit (x64) - Express, Standard, Enterprise Edition Note: Also find attached ...
iVend Handheld for Windows
Customer Query: Are we still supporting handheld for windows in iVend 6.6 Support Comment: Yes, we are still supporting handheld windows in iVend 6.6. But the development is locked and no enhancement will be done.Customers can find the installer from ...
IVEND HANDHELD FOR WINDOWS
Customer Query: Are we still supporting handheld for windows in ivend 6.6 Support Comment : Yes, we are still supporting handheld for windows in ivend 6.6. But the development is locked and no enhancement will be done. customer can find the installer ...
