Stock mismatch due to replication of data for HO, Store and Offline POS.
Product Version:
We have analyzed that in the 6.6 version stock mismatch happened due to replication of  data for HO, Store and Offline POS. We suggest having the latest patches on the 6.6 version to avoid such inventory mismatches. Once we applied the latest patches on iVend 6.6 version inventory mismatch problem.
Steps to be followed:
1. Please install the iVend 6.6 version on HO, Stores  and Offline POS.
2. Take a consolidated latest patch and apply on HO, Stores and Offline POS.
3. Do all types of transactions on Stores and offline POS.
4. Automatically data will be replicating to HO then SAP B1.
5. Verify and match your inventory between SAP B1 and iVend.
Constraints / Scenarios:
    • Replication stuck and Not Moving
      Problem: Replication not moving from HO to Specific Store. Symptoms: Replication Log File Not generated and Event Viewer is showing "INVALID CLASS ERROR" What need to be Check : 1. Right Click on My PC 2. Click on Manage 3. Now Go to Services and ...
    • Replication skipped from offline POS to the Store Database
      Product version: iVend 6.5 updates 6 with offline POS Problem Statement: Replication skipped from offline POS to the Store Database. Proposed Solution/Workaround: It was a known issue with a dated version on iVend using offline POS with replication ...
    • Replication is not working for Offline POS
      Problem Statement: Replication is not working for Offline POS as shown below (Connection status Is Red): Symptoms: Below are the known symptoms: API Service is either not configured or working properly. IIS (Internet information services) is not ...
