Replication is not working for Offline POS
Replication is not working for Offline POS as shown below (Connection status Is Red):
Below are the known symptoms:
  • API Service is either not configured or working properly.
  • IIS (Internet information services) is not installed on the server.
  • Replication service is stopped or not configured properly.
Below are the possible workaround or resolution points:
  • Go to the Management console of Enterprise/Store (For which the offline POS is configured) >Administration > IT Administration > API Health check > If the API Health check is successful then API service is working fine otherwise please check the API service configuration.
  • Please try to ping the HO IP/Store IP (For which the offline POS is configured) from the offline POS server and check if they are pinging successfully or not.
  • Restart the IIS and iVend Replication service in both the servers.
Case Study:
Incident: INC0027705
Version:
iVend DemoStack 6.6
Issue:
Replication is not working for Offline POS.
Cause:
API service was not configured at Enterprise (Offline POS was connected with Enterprise).
Resolution:
Configured the API Service and Reinitialised the Offline POS after which the issue was resolved.
