Session 1.3 - iVend Retail Management Console
In this chapter we take a look at the iVend Retail Management Console Configuration.
Review each topic unit and then test your knowledge within the videos or by completing the separate quizzes you find within the course itself.
Complete all the units in each session before moving on to the next chapter.
Management Console Role Based Layouts - Part I
Watch the following eLearning video tutorial — ScreeManagement Console Role Based Layouts — Part 1: Screen Design Customisation (Display Profiles)
Then complete the quiz that you will find at the end of the video tutorial.
Quote
You should aim to achieve at least 80% (e.g. 4 out of 5 correct answers) before moving on to the next chapter. If you get more than one (1) wrong answer then we recommend reviewing the video again as we consider anything greater to be a low score and indicates more revision is required.
Click on the video below to start the presentation...
Video Link: ScreeManagement Console Role Based Layouts — Part 1: Screen Design Customisation (Display Profiles)
Management Console Role Based Layouts - Part II
Watch the following eLearning video tutorial — Management Console Role Based Layouts — Part 2: Screen Design Customisation (Search Grid Column Definitions)
Quote
Session 1.2
Session 1.4
