iVend Upgrade
iVend Upgrade
Problem Statement :
The "Require manager approval" button on the POS User menu screen either disabled or removed from the current position. This is because users often tend to click on this button unintentionally when they want to click on the "start manager override" button. This is because the two buttons are right next to each other.
Symptoms :
Not Applicable
Resolution/Work Around :
It is not possible to disable or remove start manager override/Require manager approval button from UI.
Recommendations /Suggestion :
If there is business requirement , suggest to check with Custom Development team  for its feasibility .
    • iVend Store Upgrade Challenges
      ******Internal to CitiXsys******* Product Query: A Customer running iVend 6.5 update 5 with 40 + Stores across the region and they are planning to upgrade to 6.6. The Customer has come up with the below plan : 1. Upgrade iVend enterprise to 6.6 at ...
    • iVend Upgrade - Best Practices Overview
      Purpose The purpose of this article is to introduce the CitiXsys iVend Partner community to an overview of the recommended steps to be followed while upgrading the iVend Retail applications in accordance with best practices. Best Practices The ...
    • iVend Retail 6.6 upgrade 6.4 and above
      Query Is this feasible to upgrade iVend version 6.4 directly to iVend version 6.6 ? Support Comments Yes iVend Retail 6.6 can be directly upgraded from iVend Retail 6.4 and above.
    • How to upgrade iVend 6.5 update 6 to iVend 6.6
      Environment: iVend 6.5 Update 6/6.6 integrated with SAPB1 Problem Statement: How to upgrade iVend 6.5 update 6 to iVend 6.6 Resolution/Work Around: Kindly, download the 6.6 upgrade manual (iVend Retail 6.6 Upgrade Manual ) from below link: ...
    • Upgrade iVend version from 6.5 to 6.6
      Environment: 6.5.X Statement : Is there any guide to show how to upgrade the iVend version from 6.5 to 6.6, step by step? Resolution: iVend 6.6 is a quantum jump with various new technologies such as Quartz, Signal R, GZip MS IIS, SQL Servers, etc. ...
