How to block prices in stores
Problem Description:
How to block prices in stores, for example I don't want my administrator in the POS to go under a certain prices for wholesales.
For Example :
  • The seller wants to sell an item at a lower price because the buyer is buying more than 3 items.
  • I want that the seller in the POS, cannot go under 20% of the original price in ALL items in the store.
This  type of functionality is not available in base iVend as requested.
N/A
    • Block User Menu Button on POS
      Problem statement User Menu button found in iVend POS. Environment iVend 6.6 Symptoms User is developing an Add-On where they need to block this button so that only Manager type users can access. However, user cannot find any event or example that ...
    • Block the User Menu button found in the iVend POS
      Query There is a query regarding the User Menu button found in the iVend POS. Customer is developing an AddOn where they need to block this button so that only Manager type users can access it. Below is the screenshot for the same: Response This ...
    • Block iVend Handheld Operation with iVend MC Security Roles/Rights
      Environment : iVend 6.5 Update 6 with SAPB1 9.2 Problem statement : Need to Block some Operations as per configured security roles using iVend 6.5 Update 6 with iVend Handheld Resolution/Workaround: This feature/functionality is not available in ...
    • Block UOM from UOM Group iVend MC/POS
      Environment: iVend 6.6 with SAPB1 9.2 Problem Statement: There are multiple UOM , part of UOM Group definition and cashier can select any of UOM on iVend POS screen . cashier is required to restrict for selecting only one UOM on POS screen, other UOM ...
    • Prices not getting updated from SAP B1 to iVend after customer upgraded to iVend 6.6
      Product version: iVend 6.6 Problem statement: Price update issue on SAP after connection of iVend 6.6 addon. After upgrade from iVend 6.5.6 to iVend 6.6, we are facing an issue with updating prices for products. This is occurring for random products. ...
