Block UOM from UOM Group iVend MC/POS
iVend 6.6 with SAPB1 9.2
There are multiple UOM , part of UOM Group definition and cashier can select any of UOM on iVend POS screen . cashier is required to restrict for selecting only one UOM on POS screen, other UOM , he can select.
Scenario:
It is about this product .Our supplier sells it to us by Kg, but he gives us a 4.5 Kg roll. So, in sap we have a unit of measurement for converting Kg to Roll, and the roll conversation is set to 4.5 kg per roll.So we should only sell in multiples of 4.5 kilograms, but in the POS I cannot block that part.
There are multiple UOM , part of UOM Group definition and cashier can select any of UOM on iVend POS screen . cashier is required to restrict for selecting on UOM on POS screen.
POS picks the UOM from UOM group definitions and in iVend UOM Group definitions, we cannot mark any UOM disabled. that's why POS displays both UOMs. A workaround may be to update/change the UOM Group definition from SAPB1
N/A
