Error on setting site id on store replication
During the store initialization an error message has been encountered while
configuring the Replication service for the store and the store were not initialized.
Below is the attached error.
Proposed solution:
The issue usually occurs when the local Database and Server name is entered on the Enterprise.
To fix the issue, the Enterprise Database and Server name should be configured on the Enterprise tab
Steps/ Constraints:
Carefully read the Labels of the Configuration window and update the details
Replication stuck and Not Moving
Problem: Replication not moving from HO to Specific Store. Symptoms: Replication Log File Not generated and Event Viewer is showing "INVALID CLASS ERROR" What need to be Check : 1. Right Click on My PC 2. Click on Manage 3. Now Go to Services and ...
Replication not working
Environment: iVend 6.6 Problem Statement: Replication service not working due to controller application Error Screenshot: Solution: - This issue happened due to there’s an error showing from controller application when customer removed this ...
Addon information was not updated for newly created store
Require to make the inventory as Zero for particular store
POS Site id : New Point Of Sale
Product Version iVend 6.5 Update 6 Patch 2 Problem Statement POS Site id : New Point Of Sale Proposed Solution Customers are facing an issue, in which they define new pos for a store, it takes the same prefix of B store. POS site ids are system ...
