Coupon ID does not exist
Coupon already available on management console, but in upload, it shows coupon ID does not exist.
Proposed Solution/Workaround:
Map the Coupon id and Serial number.
Steps  - Step to do the coupon upload.
Step 1 Open the Administrator >>Application Setup >> Import Data
Step 2 Select Excel file and select the correct object type.
Step 3 Map  ID as per the columns
Step 4 click on OK button and It will show the result.
Step 5 On the Bottom click on ok button.
    • Record stucked on Integration Failure Error [INV1.SlpCode][line:1], Linked value 99 does not exist
      Environment: iVend 6.6 integrated with SAPB1 Problem Statement: Record stuck on Integration Failure with Error message “ [INV1.SlpCode][line:1], Linked value 99 does not exist” from iVend to SAP. Symptoms: NA Resolution/Work Around: Require to check ...
    • coupon is applying only once
      Problem Statement Bonus Buy, Special Price List and Coupons are not working together in iVend 6.6 for example We have the product A and Product B, C, D. Now Product A Base Price is 1000 and special Price 100 discount. Product B Base price is 2000 and ...
    • How the Coupon Redemption Data Syncing Coupon Information from iVend to SAP B1.
      Problem statement : How the Coupon Redemption Data Syncing Coupon Information from iVend to SAP B1. iVend version : 6.6 9351 ERP Version : SAP B1 10.0 Symptoms: NA Cause: NA Resolution / work around : iVend Retail 6.6 supports the creation and ...
    • Can we use a single coupon multiple times
      Environment:  iVend 6.6 9351 Product Query:  Can we use a single coupon multiple times till the coupon value is redeemed? Scenario: "We would like to create a coupon with a total value limit. For example, if the coupon value is $500, the customer ...
    • Integration Failure :Linked Value C115 Does not exist transaction
      Problem Statement There is POS sales transaction failure from iVend to SAPB1, displaying error Linked Value C115 Does not exist transaction System.Exception: DI:10000415 - Linked value C115 does not exist at ...
