There is POS sales transaction failure from iVend to SAPB1, displaying error Linked Value C115 Does not exist transaction
System.Exception: DI:10000415 - Linked value C115 does not exist
at ReplicationSBOIntegrationWinSer.IntegrationObjects.Base.ARInvoice.CreateARInvoice(DataRow[] objDataRow, DataRow[] objDataRowSurcharges, DataSet ObjDataSetTransactionAttribute, DataSet ObjDataSetTransactionLineAttribute, Decimal passedRoundingAmount, Decimal& roundingAmount, Boolean& isRolledBack)
at ReplicationSBOIntegrationWinSer.IntegrationObjects.Transactions.Replicate(Direction From, Direction To, Int32 DatasetRowID)
at ReplicationSBOIntegrationWinSer.Integrator.MainStart(DateTime LastRetryAt, Boolean& Retried)
Related value with customers or items seems to be unavailable in SAPB1.
Support analyzed the data on iVend HO using SQL procedure
exec Integration_Transaction 'Put Tranasction Key'
But all information seems to be correct , passing from iVend HO to SAPB1. It should be noticed that Integration put the information/data on SAPB1 DIAPI and DIAPI process the events towards the SAPB1 & then check if corresponding events are available or not.
Shared the one SAPB1 Note, available on internet , which may be helpful for such case
None
