Wrong Currency Symbol in reports but correct symbol in iVend.
Product version :
6.5.6
Problem Statement :
Proposed solution:
1) Check Currency Symbol in the "System Display Setting"
2) Check the culture information on iVend Enterprise Screen ?
3) Check the culture information on iVend Currency Screen ?
4) Check the culture information on windows regional settings
Steps if any :
1) Click the Start button, and then click Control Panel.
2) Click Change date, time, or number formats.
3) The Region dialog box appears.
4) On the Formats tab, select the format you want to change from the drop-down list.
Now click the Additional Settings button.
5) The Customize Format dialog box appears.
6) Click the tab that contains the settings that you want to modify, and make your changes.
For example, to change part or all of a number format, click the Numbers tab and change the setting that you want. the currency option is also available.
Constraints/scenarios : If the currency symbol is correct in iVend but only wrong in reports and other operations.
Your Microsoft Windows regional settings will influence how your date/time,numeric, and currency data types appear
when you apply formatting options.
