Version:
6.5 Update 6
Query:
What ports are required open for
1. iVend Stores to communicate with iVend Enterprise and vice versa
2. iVend integration to communicate with SAP Business one
3. iVend replications/integrations if different
Do any other ports need to be open to it to work?
Answer:
We use SQL Server Port 1433 and if you configure iVend API in IIS Web Server we use port 8080.
If, you intend to use different ports then please mention the same while configuring the system and iVend will work seamlessly for you.
