Product version: iVend 6.6 latest patch
Problem statement: The Replication service of 3 stores is disconnected from Enterprise to stores and vice versa.The Replication service was fine and running.There was no error in the application Log and we also enabled the Deep Logging in the Replication Configuration manager but couldn't find any error in the Log as well.
Restart the IIS then the Stores get connected but this process have to do every time to get the stores connected.
Kindly as per our hardware and software guide, we do not support Windows Server 2008 R2. Still, we have provided you options to configure and use the same Windows OS though Microsoft is also not supporting this Operating System.
You have two options:
Steps if any: NA
Constraints / scenarios: NA
