Product version :
iVend 6.6 and SAP B1 PL 10
Getting error on SAP Item Master Data Screen” UoM Group Can not be Changed !!”
Proposed Solution/Workaround:
Issue is handled in ivend latest add on.
Steps if any :
Step 1. Open Inventory
Step 2. Open Item Mater Data-> Search Item
Step 3. Select UOM Change from Manual to Defined UOM
Constraints/scenarios :
User want to change the pre-defined item UOM from Manual to other UOM type. It shows error while going to update in SAP window.
Note:SAP b1 PL10 with Hana Database does not require the CXS_Ivend_SP_TransactionNotification90.
